which to choose?
12 Aug 2005
Singapore
Hi guys, i'm currently using an AMD opteron 170 running @ 2.7ghz
intending to jump to DDR2,
i would like to know comparing
Opteron 170 2.7ghz
Vs
AM2 X5200 @ 2.7ghz
C2D E4400 @ 2.7ghz
will the latter 2 be faster than my opty?
if yes, among those 2 which will be faster?
Thanks
hmm does the 4mb actually affect the performance?
btw i'm looking at the asus P5B mobo, the most basic one of the P5B series..
will it be sufficient for me to get either the E4400/E6320 to 3.0ghz?
Thanks
The motherboard should overclock to those speeds. At stock there will be a slight difference in speed, i say about 5%. But its really nothing that noticeable once overclocked. The E4400 will overclock much easier with cheaper ram and motherboard.
