- 10 May 2012
- North London
OK which should I choose Dragonfly Red or DacMagic its going to be for my Laptop with my Monentom 2.0 Headphones?
Thanks![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thanks
Cyrus Soundkey![]()
OK so I got the Soundkey, but it seems to have lowered the volume of my Momentums which are ( were ) pretty load , but having said that I can hear more detail in what I've been listening to almost like they are higher ohm headphones ( I think they are 32 ohms ) .
I should say that before the soundkey I was using a Dacmagic which although much louder did not have the same detail plus seemed to have some crackling and hissing too .
That's a shame, are you going to try the Dragonfly? Audiolab M-Dac nano is another option which is supposed to be good.
