Which tyres?
Guv
Guv
24 Oct 2002
Warwickshire
I need 2 new front tyres for my ST24.
Currently there are some Dunlop tyres on there which seem fine, but are there any better ones that I should get prices for?
The dunlop's cost about £50 each fitted, so something that's likely to cost near that would be good.
Tyre size is 195/65/15
thanks
[TW]Fox said:
Get some Eagle F1's.
And you must be the only guy in the world with an ST24 on 15's :confused:
I'll get a price for the eagle F1's.
I don't like the 15's but that's what came on the car when I got it, even though it was probably a bad choice to buy the car (I should have waited for a different one that didn't have the minor problems this one did). It's done now though.
I have considered getting some new alloys for it before getting some new tyres but still not sure if it's worth it at the moment.
panthro said:
Can you not get lower profile tyres that 65?
No idea. That's just what's on there at the moment.
Would it make any difference if I got a lower profile? even though the rears are 195/65/15.
Sounds like someone has taken your propper alloys off and fitted normal ford ones, you got a pic of a wheel?
Yes your speedo would be wrong.
they aren't Ford wheels.
They look like cheap alloys.
wow, you have a nice car :D
Its funny that the RSAP does not show that much in black, or is that just in the pictures?
Does it have rear disc breaks?
needmorespeed said:
On 15" wheels the size should be 195/60/15
My Rover has 185/55/15's :) A lot of people like to put 195's on... I tried it before I got rid of the old car... the tyres looked huge. :(
Going for some low profile 15's on the GSi :D
thank you.
I was surprised at how small the rear discs/pads are when I changed them a couple of weeks ago. They looked like they should go on a Fiesta 1.1!!
They do the job pretty well though :)
