Sorry for totally just hijacking this thread but since you have actually ordered it you might also want to get more IR emitters. The hub comes with one emitter that works well but if you want something that you can directly attach to your devices I've got a pair of 4 attachable IR emitters (8 total, 2 I don't use) stuck to the front of my devices.
On "the bay" search for:
"IR Infrared Remote Extender 4 Emitter Emitters 1 Receiver Repeater System Kit"
That will get you what you want for the best price.
You're paying for the receiver part which you don't need but from the images you'll see that the emitters are separate and attach via a 3.5mm MONO plug. This is the cheapest way I found to get the emitters on their own (with 4 at a time).
However, the smart hub however expects a 2.5mm jack so you need to buy a:
"3.5mm female (jack) to 2.5mm male (plug) MONO adapter"
Should be no more than £20 for all of that allowing you to directly stick up to 8 emitters on your devices.
