Thanks, I must have had them on as SBX was always lit up on the X7.
OK, I suspect there is an element of having to 'un-train' your ears after a while of listening to those SBX software enhancements (as per the earlier poster's comments of getting used to it). From reviews it appears the D10S has a very transparent sound that could appear bland. But almost certainly a better DAC than the X7, particularly for music. Tbh on my old X7 (or even when I use the G6 now) I tended to only ever to adjust the surround for some PC games and switch all the other SBX adjustments off.
Im thinking if I got the Denon PMA600NE I could have the D10s from my pc - the call digit from the Mac mini and then just plug the headphones in to the Denon when I needed them.
I only use headphones for editing video - I use speakers 99% of the time.
Id wire it up so only optical was going from the d10s/calldigit into the Denon amp - so would this make all audio processing then be done by the Denon only? or is some still done in the D10s?
Is this what you would do ?
The big strength of the D10/D10S appears to be it can be used as a DAC for an AMP via RCA output. Or convert USB audio into digital out though SPDIF to be used on another DAC/AMP combo. So I assume in your scenario the Denon PMA600NE is doing the processing if it receives the optical input from the D10S. And the D10S is acting as a converter.
I'm not a big speaker user, but more of a headphone person so would defer to other's more informed opinion, i.e. recommendations on HiFi AMPs, which speakers etc. But your logic of using the Denon Hifi Amp with your KEF speakers makes sense.
