Which vertical GPU mount will fit my case?
Just bought the Coolmaster one to give it a shot, hopefully it will work without cutting too much from the back of the case
Cablemod do one that requires no cutting. Uses 7 pcie brackets though.
I seen that one but its a bit more, I don't mind modding case so i think I'll go with the cool master one and if the cable is no good as some people report ill go with the cable mod one
