Which VGA cable is better?
10 Sep 2013
Hey, I am going to buy one of these because my vga cable maes some ghosting thing and its really annoying.
So help me pick which one :D
3M VGA/SVGA 15 Pin DDC Monitor Cable
Premium HDMI to DVI Cable Gold 2 Metre
AMD FX-6350
XFX HD 7970 DD Edition 3 GB
Asus M5A97 LE R2.0
Corsair Vengeance 8 GB (2x4GB) DDR3 1866 memory
Western digital caviar blue 1TB 7200RPM Harddrive
Corsair CX500W
As long as you have the correct connections on either side, the first one will be the best (HDMI-DVI)
Although it may just be better getting a DVI-DVI or HDMI-HDMI cable. What connections does your monitor/tv have?
VGA and HDMI. I have this adapter thing that changes the VGA to DVI so I can get VGA to VGA. I need a cable that will do the job. My current one has a lot of ghosting. I want one that has no problems and is useful.
