- 24 Sep 2008
- St. Neots, cambs
Hi All,
This project came around because I was bored and wanted to mod something and I happend to have a lian li q08 lying around that I used to have as my server case.
This is how it looked as stock and as my file server.
The mod started by sending off my silver stone sf450w psu to get sleeved at a shop I cannot list here, it will be braided grey but with light and dark blue braid to act as a contrast. This place also powder coats cases so I decided to get the case powder coated in white as they had another case being powder coated in white so offered me a cheaper price so I went for it.
The case is currently with them and when its finished the inside, outside, hard drve cages and dvd besel will be powder coated white. Since they already had my psu that will also be powder coated. They will also be cutting a window in the side panel as well. So the case is getting modded but not by me
Cant wait to get my hands on it once it is finished.
This case is going to be my extreme HTPC and will be going pride of place in my living room (if the misses permits it!!!)
Going into the case will be:
MotherBoard: Zotac h55 itx wifi
Cpu & Water Block : Intel i3 with xspc rasa block
Ram: 4gb kingston ram
Hard Drive: 40gb ssd
PSU: 450w silverstone sfx psu (currentley being sleeved)
Radiators: 120 & 140 Black ice rads
Pump: laing ddc 10w pump
Fans: Undecided!!
Tubing: UV Blue
Fittings: XSPC black nickel compression fittings
GPU: Undecided, as it will be mainly used as a HTPC but would like to be able to play some games so i would like to get the KFA2 550TI white PCB addition as it would go perfectly with the white case.
More updates when i get the case back
Fans: Undecided!!
Tubing: UV Blue
