White LED fans??
5 Jun 2012
Been looking for some white led fans to go with the nzxt phantom 410 gunmetal I recently bought from OCuk and am really having trouble finding any? All the white led fans I've seen have either little or very bad reviews - is there no well reviewed white LED fan? I want to buy one 140 for the front and two 120mm for the sides aswell as a 140mm for the top? However I don't want to spend a ridiculous amount for fans so my budget is ~50?
I've had Xigmatek Crystal white LED 120mm & Bitfenix Spectre & PRO white LED 120mm fans & Silverstone AP121
For brightness go with the xigmateks, probably the best all-rounder of the three above, move a decent amount of air, not overly loud and the LED is a bright pearl white.
The spectre pro's performance wise are the best of the bunch, but they can be pretty loud.
The original Spectres' are quiet, have an 'ok' spec but I found the LED to be very dull on them.
The AP121's are really nice fans colour wise, and fantastic as an intake fan, can be a little noisy at times though.
