Eric's collar
Eric's collar
Is this advisable ? I was planning to get some isoprophyl alcohol but I heard white spirit and some cotton buds do the job.
White spirit will leave a film behind. Get some iso or if you really can't find any, use the cheapest vodka you can get your hands on.
Are you really having problems getting it off?Is this advisable ? I was planning to get some isoprophyl alcohol but I heard white spirit and some cotton buds do the job.
.Ahhh I see, it shouldn't be too hard, I just clean mine with a lint free clothHaven't tried getting it off yet but it might be better to get some iso
There you go LinkWhat on earth is a lint free cloth? Keep hearing it being batted around...
Is it just a cloth that doesn't leave bits behind?
And where can I obtain one?![]()
White spirit will be fine.
Just because you've done something countless times, doesn't mean it's a great idea.+1 always used it with no problems on countless builds.
Any residue that it leaves behind is going to be so minute that it's not going to make a measureable difference.Just because you've done something countless times, doesn't mean it's a great idea.
The parafin it leaves behind impares the properties of the interface material.
If you wear glasses then you can use the cloth that comes with your glasses case... although don't wipe your specs after cleaning your CPU![]()
