Who cuts Pizza with Scissors?
18 Oct 2002
Somewhere in the middle.
I always use Kitchen Scissors for cutting my Pizza up, Good clean slices and as easy as a Roller cutter :)
I imagine this isnt a common thing, if you havent tried it, then do so next time you have a pizza :)
For something that is specifically designed to cut pizza the hardest thing ive used to cut pizza is a pizza cutter.
I have used scissors before and I agree it does cut it well but I generally use a bread knife.
Pizza rollers are alright if they're decent ones. If I can't be bothered to slide it off the pizza tray I'll use scissors. I often find that because you have to lift the pizza slightly, the toppings can start to slide off though.
If you pizza cutter isnt too sharp then I find it seems to push pepperoni etc about instead of Slice it.
This is where Scissors prove their worth. On Pepperoni Sliceage! :D
maybe your pizza cutter sucks? i know the plastic ones are useless.
weve got a nice metal one with a fairly sharp edge and it cuts a pizza with little effort
Nope, I just use a socking great knife and a bit of downward pressure.
I do use scissors for slicing up pita bread into strips for dipping in stuff, mind.
