it does not break the forum rules or im having a brainfart?
http://snoop1050.pwp.blueyonder.co.uk/Untitled-1.jpg
400px × 75px IT IS EXACTLY THE RIGHT PIXELS?
19.7 KB (20,242 bytes) IT IS 0.3KB UNDER THE MAX FILE SIZE?
IT DOES NOT CONTAIN MOSTLY VERY LARGE WORDSWhat is the signature for? [edit your profile]
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted
try asking the mods
