Ok so ATM I have:
Asus A8R32-MVP Socket 939 motherboard,
Corsair XMS 4400PRO 2x 1gb RAM
AMD 4800 Socket 939.
I'm considering an upgrade.. already.. to these
Abit AW9D-MAX Intel 975X (Socket 775)
Corsair 2GB DDR2 XMS2 Dominator PC2-6400C4 TwinX
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB)
Here at OcUK which comes to £489.
Worthwhile upgrade?
I'd definitely consider it if I can sell my mobo/ram/cpu combo for about £260-280 They are all less than 1 year old and I still got all the boxes and warranty, you guys reckon they are worth that much?
That'd mean I can get the upgrade for about £230, which Is more realistic tbh.
Worthwhile upgrade?
Do you want to go core duo because you are unhappy with your system proformance or because your caught up in the hype?If i had your set up I would wait till it struggled with a game by which time there be better components/deals available
