WHS and advanced format drives
20 Jun 2004
Essex
I've got a few WD20EARS 2TB drives and was hoping to put them in a Windows home server machine... do these not work within WHS? Or is it the case of setting jumpers 7&8?
Drives will perform ever so slightly slower jumpered.
TBH you will never notice unless your the kind of person that likes to spend all there time benchmarking drives :D
Thanks guys.
Venares - A bit off topic, but have just noticed you have exactly the same CPU / RAM / Mobo as me.
If you get a chance, can you post up your bios settings as i've found 4Ghz impossible to maintain as a stable overclock... would be much appreciated!
Also, can someone explain how I can check that my sector size is set correctly? HDtach reports 512kb sector size.... and the drives seems pretty slow...
