Why am I having to pump my bike tyres weekly?
9 Jun 2006
Purgatory
My tyres (well tubes to be more exact) seem to be seeping air out and I have to pump them up once a week. Does anyone know how or why this could be happening? Is it normal? They are 700c road tubes.
Sounds like a slow puncture, you can try covering the tyre in soapy water and see if any bubbles are forming, or just change the inner tube as they are cheap and its pretty easy.
Leaky valve, slow puncture, the cold weather does not help either.
Try using some tyre slime see if that solves the issue, should seal any punctures no matter how small without adding any excessive weight.
Failing that try a new set of tubes, i suggest Nutrak Self-Sealing Tubes, they serve me well, even had a nail go through the sidewall once and they held up against that
Is it actually going flat after a week or just a bit soft?
Tubes will lose air a little bit over time, if your innertubes are fairly old then the valve might be starting to leak.
I check my pressures before each ride (mountain bike) so it would not be an issue for me personally :p
Because the tubes on bikes are more permeable than those on cars and should be kept at a higher pressure. For example my bike - with brand new inner tubes - drops from 70psi to about 60psi across the course of a week. Keeping the tyres hard improves braking performance, lowers rolling resistance and keeps your tyres healthy for longer.
I do, on average, 200 miles a week. I don't experience a PSI drop of 10 or more, and don't need to pump my tyres weekly.
SLIME recommended?
To fix this particular problem or as a preventative measure for the future?
For this problem I'd take the tube out pump it up and stick it in a washing up bowl full of water and look for bubbles then either replace it or fix it if you find air is escaping, then you can look at sticking some slime in just in case.
