- 18 May 2010
- London
Why do we only get 4 out of the 5 primary memory timings marketed on ram?
Is it because RAS to CAS is actually two values (Read Delay and Write Delay) which is just displayed as a single value?
So for example 16 16 16 36 means the 'RAS to CAS read delay' and 'RAS to CAS write delay' are both 16?
Because the primary timings are 5 sets of values:
DRAM CAS Latency
DRAM RAS to CAS Read Delay
DRAM RAS to CAS Write Delay
DRAM RAS PRE Time
DRAM RAS ACT Time
Those are the 5 primary timings for any ram sticks so why are we ever only told about four of these values?
So lets take for example the 8 Pack CL16 3600MHz ram.
Specs say CAS 16-16-16-36 but as you can see there are in fact FIVE primary timings.
So where is this mysterious Houdini 5th timing?
DRAM CAS Latency
DRAM RAS PRE Time
DRAM RAS ACT Time
