- 14 Nov 2002
- Under the Hill
Middle of my screen is at just under 4ft while mounted which is spot on imo.
Wall mounting is fine at the right height. You're right about people putting them too high, people seem to assume above the fireplace is the right place but it's going to be at least 2ft too high.
If you're going to wall mount, sit on your sofa and see what height suits you so you can watch it comfortably.
Bubba, as long as your centre speaker is directly above/below the screen you'll be fine.
Ideally the tweeter on your centre should be in line with the tweeter on the front left and right to make front panning sound nice and smooth, since my setup is more audio orientated and I have some 5.1 audio I listen to this takes priority, I have to say though I have spent a full day watching movies with my tv where it is and have had no problems at all.
Here is a picture of my living room (WIP) the TV will sit just above the centre cabinet (you can see the holes for the tv bracket)
http://img59.imageshack.us/img59/6564/image603m.jpg
Here is another picture while I was doing some testing before finalising positions etc to give you a better idea of height (excuse the mess).
http://img23.imageshack.us/img23/6549/image522b.jpg
I think a lot of people do it because it is safer, if you have children the tvs can fall on to them and hurt them.
