Why does my internet cut out when ethernet port given IP?
Don
23 Oct 2005
North Yorkshire
I have my laptop and PC connected via crossover cable to share files etc.
They both have wireless connections for the internet. I want my ethernet to have static IP addresses but when I assign these the internet cuts off? It's like the internet connection defaults to the ethernet connection instead of the wireless conection?
How do I fix this? I have had it working before but since I formatted both PC and laptop I can't get it to work.
Cheers
Nope. Just the IP and subnet.
I have to disable the ethernet connection in order to connect to the net.
Any other suggestions?
The IP address of the PC is:
192.168.0.* 255.255.255.0
The IP addess of the Laptop is:
Should I change the IP address of the laptop to read 192.168.1.*?
Thanks
Ok, list the IPs configured for the physical and wifi connections on both PCs, sounds like you just need to use a different subnet for the wired though.
I've changed the subnet of the local ethernet connections on the PC and Laptop and they're working fine now :)
Thanks a lot!!
