Permabanned
- 14 Jul 2011
- Starship Enterprise
and also btw why cant overdrive work on my system? is it not supported?
in task manager it shows me only one core, but in my system it says athlon II x2 255
I only built it yesterday.
in performance, you should see 2 cpu usage boxes if you have a dual core, I only have one.
oh specs:
Athlon x2 255 3.11Ghz
Asus M4N68T-M LE V2 Am3 motherboard
2GB DDR3 1366mhz corsair ram
500w Arctic freezer psu three 12V rails at 18A
Msi 460Gtx 1GB GDDR5
Where does it list the amount of cores in Task Manager?
I've reset the bios, and downloaded the drivers, and that seems to have worked, but why isn't amd overdrive working, as I find it difficult to overclock from the bios!
You can't OC the video card in BIOS.
lol I'm scared of touching the bios, may mess it up, I have overclocked with overdrive before and its really easy.
So what fan thing do I have to deactivate in the bios to make it work?
No!!! bought a really bad motherboard lmfao!
