- 12 Jul 2012
I'm using Windows 7 Ultimate 64 bit.
Ive had this happen a few times in the past, if you have a keyboard or another USB device in a certain USB port, then while the pc is switched off you unplug that device and move it to another port. You then boot up the pc, after a short while you get a blue screen error message, no matter how many times you reboot you get the same blue screen error message.
If you then unplug all the USB devices while the PC is off, do a reboot and plug them back into any port the PC is switched on everything is fine and the blue screen error messages go away. What's the cause for it to do that ?
