- 5 May 2004
Hi guys been out the game a very long time and used laptops and xbox
Situations changed and laptop bust and needs replacing so ive decided to go with a desktop again with a pretty tight budget .
am5 mobo
ryzen 7600
deepcool ak620 cooler
32 gb ddr 5 6000 cas latency 30 ram
be quiet pure power m 750w psu
2 tb nvme
Now i have £300 ish left for a gfx card and simply just dont know lol. Done a lot of reading and then get put off by things such as ooooo 8gb vram no good now, that arc is good but struggles with older games. the amd is good if you dont want ray tracing.
To make it clear for when you reply i have a 22 inch 1080p 100hz monitor which i intend to keep. I will mostly be playing single player games ( xbox for multiplayer ) and i would like to replay the gears and metro series as well as new titles and gamepass games.
I would like a card that will do high settings and be good for the next 2-3 years with settings being lowered in time. I must admit im really tempted to go for the asrock intel arc b580 , After looking around on other threads and forums though cards such as the rtx 4060 ( even 8gb version) , the radeon 7700xt and even a rtx 3070 have been suggested instead.
Thanks
am5 mobo
ryzen 7600
2 tb nvme
Thanks
Real would like the b580 but people say if you can put up with the issues. Bar the older gen cpu issue i cant seem to find what these other issues are.
