Why is deeplinking not allowed ?
It's too much work to moderate and decide which sites are safe and which aren't. It's easy just to say no hotlinking full stop.
It only takes 30 seconds to upload the picture to photobucket anyway.
or install the imgur plugin and you can right click the image > quick upload or selective upload which lets you select which part/size of the screen you want to capture into an image for those sites that disallow right clicks
Sometimes you can get away with it, say if its wikipedia or something like that. But Ive had similar images blocked before. It depends, if its on a blog or user controlled site then its going to get blocked right away.
I now use imgur because it has the best features.
If you host pictures yourself, got some webspace etc, how can you tell who have been hotlinking off you? Can it be done on my Virgin (formerly NTL) webspace?
I hosted on blueyonder at one point then google decided to flag the whole domain as a malicious website :rolleyes:
I think somehow people got prompts or whatever from there browser for it and I got an infraction for " Spammed Advertisements"
Not with Virgin's webspace, it's too basic, don't think you can access any logs.
With paid hosting you usually get something called "cPanel" it's basically a control panel for your entire hosting account and you can check detailed logs for referrer links to see if any external sites are linking to your images. You can even set up a referrer whitelist so any domains which aren't allowed will automatically be shown a pic of a penis instead of the actual image. ;)
Because you have no control over the original image and it could be changed to anything.
This!
You're originally linking a picture of the gorgeous Emma Stone, the owner of the original image may take offense to this and change the picture to a BBC!:eek:
you can see bandwidth usage for each individual file on your website as far as I can remember.
I'm not sure if you can see where website traffic is coming from though etc
It's so you don't open a page & have some fellas wanger sticking out your monitor.
Is that the same as hotlinking?
[FnG]magnolia;25095976 said:
Was this ever answered or am I missing something?
No, hotlinking is directly using any linkable object located on someone else's server. Typically an image, it can also be some sort of embedded php script, css script. Basically, anything which uses up resources on a remote server every time someone loads a page from your personal local server.
Deep liking is merely describing any pasted/typed link to a resource in a domain which goes deep several levels, eg bob.com/images/ocuk/bob.htm that's a deep link just because it goes "deep" to a specific file within several folders.
