If it was anybofy else, I would have thought that they meant they figuratively threw them in the bin, but since it was Kaapstad it is possible that throwing them in the bin was meant literally.Fury X was the worst card AMD produced in the last 10 years, it was struggling for memory from day 1 @2160p.
I was so disgusted with the 4 I bought that I threw them in the dust bin in the end.
Having said that if the Fury X was used at a lower resolution and not in mGPU it was a pretty good card.![]()
How is that Nvidia shill nonsense?
Your the guy complaining that 10GB is not enough at 4k when you tried to run 2 4k panels in VR on a 3080. Real smart...
When the Furyx was released all that was ever talked about on these forums was how 4Gb wasn't enough.The vram argument has only started, since AMD released their 68/69 cards with 16GB, now any lower than that, is not enough, its insane that we've gone from the day before those cards came out, our vram was fine, to the day after when they came out, its not fine, we ain't got enough, our cards have been ****** in 1 single day, and whats funny is, we have a card with 24GB, that hasn't rendered the 16GB vram on those cards obsolete, and not one single post saying that its not enough, and they can still run games to this day fine, bizarre!.
OK this is a good example of VRAM impacting the 3070, if it's the same benchmark I looked though it's not about 4k res (the 3070 is level pegging with the 2080ti at 4k), it's about 4k max settings and RTX at the same time. Would love to get my hands on these setup and do some tweaking of the settings to see if you can alleviate this. But to be fair the 208ti had a MRSP over £1k whereas the 3070 is below £500, these high end cards typically come with a fistful of VRAM. I think it's better to compare with the 3060 12GB, this beats the 3070 at 4k Max RTX, as does the 6700XT. I simply wouldn't use those settings though because the framerate is too low for my liking on all these cards, which is what I frequently come back to when assessing this, in order to create a VRAM bottleneck you have to crank the settings up so high you are dropping down to double-digit framerates anyway even if you had a TB of VRAM.RTX 3070 falls flat to 43 FPS in RE:Village. From a normal perspective, you only see 3070 averaging 43 FPS at 4K, in reality, without VRAM constraints, its equal 2080ti renders 77 frames
Yeah like I said above VRAM is a mega old argument, being had since at least 2002 if not before.When the Furyx was released all that was ever talked about on these forums was how 4Gb wasn't enough.
Oh look, Wrinkly is going on about the utter crud that is CP2077 as if it is some PC Nirvana. How's is your 3770K handling that 3080 lol.
Why does this upset so many kids 'lol'?My 3080 plays 2x 4K in VR perfectly as well as can be expected and only 1 very limited scenario does the VRAM limits manifest.
Let me guess your pathetic retort... something something RT something something CP2077 is like real life.
Yeah that's the normal cadence, upgrade every other generation (no need to worry about VRAM as you'll have a new card in 2 years time), but to be fair in more recent years you can get away with running cards a bit longer as the pace of progress has slowed.
I can't believe you'd do that, Kaap.![]()
