why no more 5400rpm drives?
17 Jan 2004
Liverpool
i mean the new drives out now are all 7200rpm arent they? the 5400 ones used to be cheaper so handy for just storage.
do they not make them anymore?
presumably not the demand any more, and the costs of doing small runs of 5,400rpm drives would be higher than just switching to only making 7,200rpm drives :)
It's the same reason a 40gb (£35) drive is only a few pounds cheaper than a 160gb drive (£45), the "lesser" drive is barely any cheaper to make/distribute.
Not many do but Samsung still make a 160gb IDE drive that is 5400rpm it appears. If you want a SATA drive though I think you can only get 7200rpm, even although they may cost slightly more I'd probably still go for a 7200rpm drive.
i was just thinking of the huuge 500GB drives and was hoping there would be cheaper ones that ran @ 5400rpm instead :)
ah well. looks like those days are over
peetee said:
i was jus thinking i could do with a 500gb drive or something but yea there too expensive :(
Get 2 250GB's and a interface card with JBOD
I have just bought two 250GB WD RAID ediition HDD's for £95inc & a RAID card for £10inc
