- 5 Feb 2006
can i ask why people use linux , is it a lot more stable ? Im not exactly clued up on it but from what i understand it is also a pain to install stuff , having to write code and such
zhx said:can i ask why people use linux , is it a lot more stable ? Im not exactly clued up on it but from what i understand it is also a pain to install stuff , having to write code and such
) but I'd suggest a lot of Linux distributions are a lot easier to maintain than Windows (not sure how they compare to any Mac OS). On my Gentoo box I can upgrade my install with a coupla commands, and portage (Gentoo's package management system) will even update to newer (patched) versions of games such as NWN and UT2004 (unless I specify for it not too) when they become available. It will also upgrade Open Office etc when new versions are released. I don't believe Windows will automatically upgrade Office XP to Office 2007 or whatever automatically (and for free).
Hades said:If you're happy with Windows then stick with it. If you're keen to try something new and have fun learning then try Linux. Incidentally someone at my work installed the beta of Vista and even without the fancy graphical extensions (forget the name of them), it used over 500mb of memory just sitting there doing nothing. A fresh install of Ubuntu Linux takes up around 150mb on my system.
Hamish said:Thats because the new Windows memory manager uses all the RAM it can in order to speed your system up![]()
