- 16 May 2007
Hi people
I am in a bit of a quandary at the minute. I have a NEC MultiSync LCD 2070VX which has a resolution of 1600x1200 @ 4:3. I am happy with the screen apart from the aspect ratio and have been contemplating replacing it with a widescreen version. The only problem is the 1900x1200 24" monitors seem over priced when considered against their 1920x1080 counterparts.
Whilst I would like to change I do not want to take a retrograde step. I also do not want to spend much money (age old problem). I had been looking at these two options as no frills replacements
http://www.overclockers.co.uk/showproduct.php?prodid=MO-057-BQ&groupid=17&catid=510&subcat=
I am not bothered about tilting, height adjustable or swivelling stands it just needs to be functional with a decent picture quality (not for gaming).
Would the above monitors be ok as replacements and for those who have gone from 1200 to 1080 is it a noticeable difference?
Would like to hear peoples views - Thanks
From what you say I think the reduction from 1200 to 1080 may indeed be a retrograde step. Might see if I can borrow a 1080 monitor to compare.
