wierd problems oc settings locking in bios
13 May 2007
On the wagon, sorta
really wierd problems are starting to pop the ugly head up, my system has ran rock solid for about a month now from new but starting yesterday it has had problems posting with the overclock which i might add is quite moderate for the chip.
now today i went back to my computer and vista had put it into a dormant state (not sure of the proper name) so i hit a key on the keybored to start it back up again but the screen went blank and my gts fan spins up full blast as if the 4 pin mobo connector wasnt connected, so i had to turn the pc off then back on and it didnt make a differance just full speed fan and black screen.
so i unpluged the power cable from the psu and left it for a minute, pluged it back in and it booted streight away. i lowerd my oc from 265fsb multi x8 to 250fsb with the same multi which is what i had before then and rebooted, now the bios has that setting saved and loaded yet cpuz shows the cpu to still be running at 265 @ 2.12ghz????
i have cleared the bios and loaded in a new speed but now for some reason the first speed i load in is the one that sticks any speed i try to put in after than will save in the bios and thats what i see but cpuz shows the cpu running at the origanel speed i put in first.
any one with any idea's please as im really not sure whats going on.
