WiFi Extender/Booster
Awesome, honestly don't know why that didn't click before :cry:. Is there any decent, some what cheap routers out there that could be recommended. Don't want to break the bank
Depending on what you want to do, plenty.
What’s your budget?
What you can do is get a router that can run OpenWRT which is a highly flexible open-source OS.
Don’t run stock Asus routers though, they have an unpatched vulnerability last time I looked.
What’s your budget?
Would be for, phones, chrome cast, tablets, No gaming as that would be wired. Budget would be kind of tight, hoping around £50.
So below is a list of WiFi 6 openWRT compatible routers, I’m sure that one will be close or within your budget.
I don’t have a router model to suggest as I’m not fully up to speed with routers as a whole but someone else on the forum might have a good suggestion.
