Can you even connect antenna's to the super hub I don't think you can
I'm guessing you could probably get better antennas for the machine on the end.
Do you know what power line adapters are :S?If I get power line adapters should I connect them to the superhhub?
What is the purpose of having another router as it wod be on the same place as my super hub as as that's the only place I have a cable connection.
Either way still need another router
So do you think they will work in my situation
