Everything seems good with this new build except the wifi keeps disconnecting and I can't figure it out.
Windows 10, wifi adapter from the bay.
When I start it up it's disconnected the connects, perfect. Then I open Steam and continue a download which is fine for maybe 3 minutes then I notice the time remaining getting longer and longer until I look to the taskbar and the icon changes to disconnected.
I'll try and reconnect but it says it can't, so I turn the wifi off and on and try again.
I've exhausted my Google-fu, been through all the settings like turning off the 'allow this device to turn off' thing and been through changing between public/private which seemed to make it work.
It's a new build so I'm pretty sure I've downloaded all the drivers, been to the MSI site, AMD etc. I even tried a driver thing where it scans the PC and sees what you're missing so you can download it, I forget the name.
My trouble is the adapter says it's unbranded and there's no name on it. The description says the same but also says TP-Link TGR1900 but all I get for that is a router hub of some sort. I just don't know where to go from here.
EDIT: I have it set up to one of my two monitors so I'm sure it's not my own wifi as my own PC stays connected while this one drops out.
