Wifi Site Survey/ Heatmap tools
23 Mar 2005
Is there any free /cheap enough for 1 use tools anyone can point me to? I have a floorplan and would like to get a better mapping of where would be the best place to put some access points for the house and outbuilding.
There are, but they aren't free. Doing this work would usually be a several step process - you do a predictive survey on a floor plan, then you put an AP in the locations that the predictive survey suggested and get actual data in the space, and then you do another survey after the APs have been installed to verify that it meets the design goals. Basic apps that you walk around with on a phone don't really help much, especially with sources of interference that aren't Wi-Fi. Companies like Ekahau make these systems.
Ubiquiti host a basic desktop survey application but it's just predictive https://design.ui.com/wizard
nothing free for what you want to do, the industry leader is a product called Ekahau.
We got a third party in to do this for us, some fancy handheld tablet with a wireless dongle and the Ekahau running on it.
If you are using Android you can use WiFiman for doing a heat map (not sure if you can on iOS). I then drew out the floorplan scanned it on to my PC, and then overlayed the heatmap image/export from my phone. Easy peasy. :)
I know it is rough but it does the job. Example when I was mapping out my bro's house:
Ekahau heat mapper used to be free. If you can find an old version, it still is ;)
