Wifi weird issue
19 Jan 2006
Hey guys,
On my laptop which I have just recently formatted and reinstalled everything I have a strange wifi issue. The Wifi light is off yet works fine, then when I switch it on with the toggle switch the light comes on but the wifi stops working.
Any ideas on how I can change this?
Thanks
Jonny
What WIFI card are you using (or what laptop if you dont know) and are you on linux or windows?
//TrX
Hmm, would be able to help you more in linux TBH, but it may be worthwhile uninstalling the driver in vista's hardware manager, then reboot, and let it re-detect/install the card from the latest drivers over the web (Use a wired connection)
//TrX
Id try uninstalling it and reinstalling. To be honest it might be controlled by some additional Acer app.
I wouldnt be to bothered about it though, just a light!
