wifi6 or Ethernet
1 Mar 2024
Leeds
My EE rougher is wifi6 compatible, but i moved my Pc today and the rougher is now less than a meter away whats the best option?
my internet is full fiber is 150meg if it matter
Ethernet is Realtek 2.5Gb Ethernet
wifi is 2x2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax)
Wifi6 doesn't even match up with Gigabit ethernet let alone 2.5Gb
i genially fell into the wifi speed claims, i sure i read the wifi 6 was on par with 10Gb. obviously i didn't :rolleyes:
EDIT: no this is wrong... but i did hear it was silly fast
With my own testing on 5GHz WiFi 6 can reach around ~900mb... but that assumes I'm close to the router/access point... which at that point I might as well be wired.
But it's not just speed, there's also latency, WiFi will always have a bit more while ethernet is pretty much near 0ms (to the router).
I decided to order a shortish Ethernet cable to connect my Mac Mini to my router. I believe my Mac Mini is capable of the latest WiFi speeds but my router isn’t.
My router is supplied by my ISP and I can’t change it, I’ve got a gigabit internet connection so do benefit from the extra speed with wired.
I haven’t got a GF/ Wife to moan about a 5M cable run across the bedroom floor and ordered a yellow cable as it was the cheapest.
like this haha, this is why my pc went upstairs. id mentioned moving it back downstairs a few times but got no reply.
played squads till 3am 4 days in a row... today we went desk shopping :D
tbf the cables on here are very cheap
Not to mention the more devices you have using the WiFi the slower overall it will be.
Save WiFi for your mobile devices or stuff that can't be wired.
Ethernet Cable every time, if you understand why, the following will make sense
Below shows several tests from 2 devices using WiFi6 in seperate locations in the same room and 1 device using a cable, bottom test.
WiFi 6 PC1
status: udp download
time-remaining: 18s
ping-min-avg-max: 1.79ms / 2.49ms / 10.7ms
jitter-min-avg-max: 1us / 501us / 8.38ms
loss: 0% (0/200)
tcp-download: 810Mbps local-cpu-load:80%
tcp-upload: 819Mbps local-cpu-load:45% remote-cpu-load:0%
WiFi6 PC2
time-remaining: 16s
ping-min-avg-max: 1.63ms / 1.96ms / 9.12ms
jitter-min-avg-max: 1us / 240us / 7.28ms
loss: 0% (0/200)
tcp-download: 694Mbps local-cpu-load:70%
tcp-upload: 635Mbps local-cpu-load:38% remote-cpu-load:2%
Network Cable
time-remaining: 22s
ping-min-avg-max: 359us / 419us / 979us
jitter-min-avg-max: 0s / 43us / 578us
loss: 0% (0/200)
tcp-download: 939Mbps local-cpu-load:50%
tcp-upload: 933Mbps local-cpu-load:60% remote-cpu-load:2%
Wi-Fi is half duplex, only one station (AP or Client) can talk on the same frequency up to the threshold of the clear channel assessment at a time.
As that channel gets more congested, your device has to compete for air time amongst other devices.
Simply said, if it doesn't move, wire it, if it moves, wireless.
Happy to send you some relevant blog posts.
