- 16 Jan 2003
- Nottingham
Whilst wired is technically better for the most part, you won’t really notice on a 150Mb connection.
nope 100% binned itI’d look in your EE routers box for a cable before ordering one.
nope 100% binned it
she made me have a clear outYou…binned…a…cable?
For downloads sure, but for latency sensitive operations you certainly will and that’s before we consider CCA and other interferes.Wired but you will probably not notice a difference in reality.
Wifi 6 can easily cover your 150mb internet with plenty of change and unless you have a material amount of local network traffic between your devices you’ll be miles off the minute of wifi.
Difference between wired and wireless for me is in the region of 6-7 ms, hardly going to be noticed.For downloads sure, but for latency sensitive operations you certainly will and that’s before we consider CCA and other interferes.
tbf i have noticed a big drop in game ping.Difference between wired and wireless for me is in the region of 6-7 ms, hardly going to be noticed.
Wi-Fi relies on RF which is different in every environment. What you notice may be different to others. It's the variation in ping rather than a blanket reduction.Difference between wired and wireless for me is in the region of 6-7 ms, hardly going to be noticed.
