I am seriously thinking of ordering my first SSD within the next week or so, mainly because I have had my Seagate Barracuda 250GB and 500GB Sata 7200rpm hard drives for a long time. I have just recently done a new build and I think my hard drives are bottlenecking or holding back game performance.
In certain games I get major stutter/pauses where I believe the Hard drive is accessing/reading some of the game data. For example GTA IV is pretty bad because as you drive around it seems to be constantly loading the new game data and I get drops in FPS when this happens, if I stand or walk around however there is no lag so I know my PC is capable enough.
The front of my tower I can see the HDD activity LED, I can see this flashing when games start to lag. Most games it is not a problem as the game data must be loaded into memory or something.
Other than speeding up the OS and game load/save times would a SSD help smooth out the problems I mentioned above? The same applies to Skyrim when new map areas are been loaded - then it stutters.
My PC is the one in my sig, I think these Sata hard drives are the weakest link. Windows 7 WEI scores are:
As I have never used or worked with a SSD I could do with some advice regarding which is the best one to go for? Faster read and write times would be better? Which brand? etc
I was hoping to get 120Gb or more one and partition one side for Windows 7 and the other for programs and games etc. Price range between £80-£130.
Thanks
Thanks
