will cooler fit
Corsair 600T
Specifications
•Dimensions (mm) 265 x 592 x 507 (W x D x H)
•Material Steel, plastic
•Colour Black
•Front Panel Power and reset switches, 4 x USB 2, 1 x USB 3, stereo, mic, FireWire, fan controller
•Drive Bays 4 x internal 5.25in drive bays, 6 x internal 3.5in drive bays.
•Form factor(s) ATX, micro-ATX,
•Cooling 200mm front fan mount (fan supplied), 120mm rear fan mount (fan supplied), 200mm/2 x 120mm roof fan mount (200mm fan included)
•CPU cooler clearance 180mm
•Graphics card dimensions supported 340mm with drive caddy, 460mm without
Source: http://www.bit-tech.net/hardware/cases/2010/09/23/corsair-graphite-600t-review/
Sapphire Vapour X
Specification:-
- Socket support: Intel LGA 2011/1366/1156/1155 & AMD FM1/FM2/AM3/AM2
- Dimensions: 135 x 110.4 x 163.5mm
- Material: Vapor chamber with 4x 7mm heatpipes
- Fan: 2x 120mm fans supplied
- Noise: 17 - 37dBA (PWM)
- Airflow: 77cfm x2
- Cooling capacity: 200W
Will fit easy. :)
An extra £5 would get you this cooler (if you're buying new): http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AL
