The 650W will be fine, as long as you don't want to overclock the card. Your 8350 will bottleneck it in some Direct3D 11 games. But it will not in Direct3D 12.
yes mate il be slightly overclocking it
should be fine if you only want to overclock it slightly.
It is called progress my friend. Display ports can do far more than Dvi ports overall and take up less space.
not to worry ive asked in the new products section to see if they can get us some![]()
Oh dear, must be getting old..
i would not be supprised if the fury comes with a dp to dvi adaptor, my asus 7970 had one in the box
will my specs in my signature bottle neck the fury x water cooled version to you reckon specifically the 8350? and will the corsair rm 650w be enough? and will there be gigabyte, saphire, msi etc. versions of it next week?
cheers guys
