will I lose installation partition if I use dban to wipe laptop.
22 Nov 2002
Liverpool
Hi I have a Lenovo ideapad 510. I am wanting to use dban to erase the drive and do a fresh install.
Does dban erase all partitions or would it leave the one that had the recovery files on?
James
DBAN will erase everything including OS and any storage attached to the computer, use it at your own risk. You can burn the ISO to a USB and should only really be used if you intend to sell/get rid of an old mechanical drive, though I believe a newer version does work with SSD.
As poster above stated, if you just want to do a fresh install then delete all the partitions during the Windows installation.
