Will I need a new power supply?
10 Jun 2017
ok so I have a Asia p8p67 motherboard with an i7 overclocked.
32gb memory.
Two Hard Drives and two SSD cards.
Network pci card.
A 2gb gtx 560.
A water pump for liquid cooling and a lot of LED's and LED strips. Finally 4 140mm LED fans.
So I'm upgrading the gpu to a gtx 1080 to match the level of my other components.
I have a nzxt power supply 450, would I need to upgrade this? I only purchase white components :).
I would upgrade to a good quality 500-600W unit. 450W is pushing it under full load, especially with your overclock.
If you're restricted to white, then either of these would be a good choice:
https://www.overclockers.co.uk/supe...0-plus-gold-power-supply-white-ca-043-sf.html
https://www.overclockers.co.uk/supe...0-plus-gold-power-supply-white-ca-024-sf.html
The 650W model will give you more headroom and is only £10 more. I was going to mention that you can't turn off the LEDs on those PSUs, but you seem to be keen on LEDs!
Thanks really like those! Even the LED's you can't turn off :D
