chaparral said:Why do you want to from a x1900xt to a x1950pro ???
Your lucky..sup3rc0w said:My current 1900xt is the loudest card you could ever imagine, and I hate it. It literally sounds like an aeroplane taking off, and im sick of it... hence wanting to jump to the Pro, just for now
ps: im on a shuttle SD37p2 ... and might as well then use the extra PCI-e slot while i wait for a better card
MeatLoaf said:
eh?Psycho Sonny said:
eh?Ulfhedjinn said:
sup3rc0w said:Because I'm still undecided if I want a 800 or not... all this talk about Nvidia not supporting them etc.
The games I wanna play comes out in 3 months (ET:QW) and later (Crysis and UT3) so there is no real need for a very beefy card at the moment (only play UT04 really)
)gurusan said:ahh if its about the noise then I would get the Zalman or if you have good caseflow the THermalright...however I don't think it comes with Ramsinks which IMO are a must.
Or you could always go water![]()
)yes they comes with the ram heatsinks...Darg said:Ah does the Zalman 900 come with RAM heatsinks? I was going to buy the zalman heatsinks seperately.
