How would I go about upgrading for free if it doesn't come with Lion preinstalled?
It depends on if it's standard spec or not. I've just put a £100k order in at work, and the custom machines have come with Lion, standard machines have SL but with the free upgrade available. I guess as new stock arrives to replace the standard stuff it will have Lion on.
100K with of macs? That must have been an awesome sight to see delivered![]()
I added the higher res screen as an option. So hopefully it will come with Lion. Thanks for all the help.![]()
It's just the new OS - there's lots of changes and improvements but the biggest (and most obvious) thing for me is the changes to Exposé and Spaces, pretty much merging them together, and using lots of gestures to control them all and to switch between the various full-screen apps.
I thought full-screen apps was a big meh when announced because a) it's not hard, and b) I actually liked that Mac apps don't tend to full screen, but they're nicely implemented with the swiping between them, and I like the way even when you full screen an app you effectively 'keep' your desktop and the app moves to its own space. Hard to explain.
I've only had a bit of a play with it so far at work (tragically can't afford the £21 til I get paid!), but while I was a little disappointed at first, the more I play with it the more I'm liking it.
I see... so in conclusion, not much of a difference then?
The order was something along the lines of 40x 27" iMacs, 1x Mac Pro, 4x iPad2, 6x 17" MBP and Thunderbolt displays and a boat load of software too.![]()
How did you get the Thunderbolt displays before Apple are shipping them? The status on the store has been "Dispatched 6-8 weeks" since they appeared.
As you say, they're about 6 weeks away.
