2 Feb 2015 at 01:51 #1 DarrenMcGregor DarrenMcGregor Associate Joined 30 May 2014 Posts 33 Will the G Skill Ripjaws 4 F4-2400C15Q-16GRK 16GB (DDR4 4x4) RAM work with the GIGABYTE Z97X Gaming 7 MoBo?
2 Feb 2015 at 01:52 #3 Puppetmaster Puppetmaster Soldato Joined 17 Jun 2005 Posts 6,515 Location Near Brighton No Z97 only works with DDR3. You need an x99 based motherboard to use DDR4.
2 Feb 2015 at 02:03 #4 DarrenMcGregor DarrenMcGregor Associate OP Joined 30 May 2014 Posts 33 OK thanks, so is the Corsair Dominator platinum the best choice to go with either 1866 or 2133?
2 Feb 2015 at 19:16 #5 Doomedspeed Doomedspeed Soldato Joined 13 Oct 2011 Posts 11,880 Location Melbourne, Australia DarrenMcGregor said: OK thanks, so is the Corsair Dominator platinum the best choice to go with either 1866 or 2133? Click to expand... Best choice for what? The 'dom plats' have good timings, style and reliability but their value is absolutely pants. If you are speccing a full build why don't you show us the full basket and give us your uses and budget, we can help better that way.
