Will M.2 WiFi Key A work on SSD slots?
22 Oct 2010
I purchased an ASRock Z270 Pro4 a while back. This has three M.2 Slots. In the manual, one (Key E type) is dedicated for Wifi. The other two are indicated to be for SSDs.
I've now gotten a hold of an intel tri-band 12860 WiGig adapter which has M.2 form factor, but with Key A. This doesn't fit into the Key-E Wifi designated slot, but the notches seem to suggest it may fit into one of the slots that is meant for M.2/NGFF SSDs.
Also the manual states that these slots will take Type2230 cards - this is the form factor of the 12860.
Will the motherboard recognise it, and can I safely plug this into the SSD designated slots? Is it just like plugging into a PCI-Express port, where the only difference is the available bandwidth/number of lanes available? Or could this damage the board?
Thanks!
No idea is the answer. In theory it should work but you'll have to try it to see. You can plug it in ok, it won't damage the board. It'll just work or not...
Interested if it willnso if you do try, please update this :)
