Will my components be compatible?
5 Feb 2013
Hi, I'm looking for some advice (first post)
I'm starting my first PC build. I'm aiming for a fairly modest but future proof build. To start I've just purchased the "Z77 Gamer PRO Intel Core i7 3770K 3.50GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle" from here.
  • CPU: Intel Core i7 3770K 3.50GHz @ 4.40GHz Quad Core CPU
  • Motherboard: Asus P8Z77-V (Socket 1155) DDR3 Motherboard
  • RAM: Patriot Intel Extreme Masters 16GB DDR3 1600MHz Dual Channel
  • Cooler: Prolimatech Megahalems CPU Cooler - Black w/x2 120MM Zaward Golf III Fans
I'm now pulling together my shopping list for the rest (I need everything except mouse/keyboard/monitor). BTW I only use a single monitor so super 3 screen perfromance is not required. I have Win 7 Professional 64 bit.
So far, I've picked the following, but I'm unsure if they will be compatible (i.e will the cooller fit in the case?), have I over/under spec'd somthing that will kill my system and have I forgotten something? Like cables or trays for HDDs??
  • EVGA GeForce GTX 660TI 2048MB GDDR5 PCI-Express Graphics Card
  • Corsair Enthusiast Series TX750M High Performance 750W '80 Plus Bronze' Modular Power Supply
  • Corsair Force Series 3 120GB SATA 2.5" 6Gb/s Solid State Drive
  • Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM HDD
  • Cooler Master Silencio 550 Silent Tower Case - Black
  • OcUK 24x DVD±RW SATA ReWriter (Black)
I'm really looking forward to doing this, never had the nerve to build a pc before and now I think I'm going to get the bug. Next stop Quad SLI, 3D monitor water cooled baby!!!!
Any friendly advice welcome!!
S
According to the official CoolerMaster site, the Silencio 550 supports a maximum CPU cooler height of 154mm (most likely due to the thik noise dampening foam on the inside of the side panel) the Megahalems is 158mm high according to the official Prolimatech website.
So you would probably just about be able to put the side panel on with the cooler's heat-pipes squidging the foam slightly, which isn't ideal, but it is workable. I would certainly want to find a way around it rather than sending something back. See here for proof of my word (my server build where the cooler was far too tall xD) :D Apart from that, you're good to go, and that's a nice spec :) You even have enough PSU power to add a second GTX660TI for SLI further down the line, with no trouble at all :D
Hmmm thanks for spotting that. Your right doesn't sound ideal, won't cool very well if covered in foam.
To be honest I found finding the case the hardest. I wanted a plane, sleek look. Not fussed with lights or windows. But still good spec. Are there any alternatives of a similar spec you can suggest? Also, how do you know if you will have enough cooling or fans for the job? Do you need special tools to measure the temps internal to case during operation?
Take a look at these case: (cant link as im at work, so you'll have to search OCUK yourself)
BitFenix Shinobi
Corsair 200R
Corsair 300R
They are the best i can think of at the moment..
No sensors are needed, they are already there.. Use HW monitor/Core Temp to show your system tempuatures.
Depending on Room temp and Overclock idle temps (CPU) should be around 30-35 and Load temps should be no higher than 60 (stock) 70 (overclcoked)
