Why are you re-installing windows after a CPU change?
well, install the dual core driver then. You wont gain anything unless your Windows install is already dodgy. I simply swapped my AMD 4000 for the 4200x2, really really no need to reinstall the OS. Only need to if you change the mobo.
Just causing yourself grief otherwise.Thanks for your reply dude![]()
