Guys
Not sure if any of you are Prepared 3D summers but I am getting poor performance - less 15fpm from my set up.
I posted a comment on the simmers forum and I was advised that I could overclock. I don’t know how!
Also I was advised that my GPU - specs below was a bottle neck and to upgrade to a 1080 Gtx.
Can you provide some advice on both parts pls.
Happy to iverclock with advice if it will help and equally will a new GPU help if it is indeed a bottleneck.
Thanks in advance - I can build a system but the specs and tech config I need help with.
Ta
Daz
Specs | Intel I7 67000k | 16GB DDR3 | Asus Z170 Pro | Nvidia Geoforce GTX970 4095MB | 240gb OCZ SSD | 1TB Seagate SDHD |1TB WD HDD Windows 10 64bit
Ta
Daz
