will this work in a macbook pro
ell you'll only be able to fit 1 in.
That link you posted was for 2 X M4 drives. You could just buy a single 128Gb drive, it'll fit fine I believe.
yeh i know its 2 i got two MacBooks.... just my mate mentioned he nearly got a sata3 ssd and wouldn't work unless motherboard is compatible... is my macbook sata3?
Should work fine, it should be Sata III, it's running Sandybridge is it not? So the chipset supports Sata III from the HDD bay.
