- 9 Dec 2015
Going to get some headphones that I can use a vmoda boom pro mic on, buying a dac because my front headphone port on case has gone and this is the amplified port and the rear motherboard one is not amplified and rubbish compared to front. I don't want any of the dacs with mic in as you are very limited in choice, my plan is to buy a dac, use the splitter on end of vmoda boom cable and run the mic with 3.5mm extension cable to the motherboard to keep it clean. Will this work fine since using mic on motherboard but having external audio device? will it also work if I completely turn off the motherboard audio then a usb mic dac.
Cheers
https://ibb.co/ykLz13q
Cheers
