Will this work?
Is the stock cooler any good on the i3? or will it be worth upgrading for prolonged gaming sessions? (i know im being a hasstle) thanks :)
Could someone also recommend a monitor for me? the GTX 460 only has 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (not sure what the mini HDMI thing is), im looking to spend about £130 including delivery. Thanks!!
My GTX came with a mini HDMI adapter (GTX 560 ti). It just saves "space" so you can have the other ports on the GPU (and things plugged into them).
Your GTX 460 may come with one.
As for monitors, your probably looking around the 22" range (on the budget side). The only two in budget are:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-058-IY&groupid=17&catid=949&subcat=
and
http://www.overclockers.co.uk/showproduct.php?prodid=MO-135-SA&groupid=17&catid=949&subcat=
Not very good on monitors, sure someone will be more helpful :)
