I have a SuperFlower Golden Green HX 550W. I want the 9590 because the 8350 is getting a bit dated.
Thanks
DJL99![]()
I dont see the CPU listed under support - http://uk.msi.com/support/mb/990FXAGD65.html#support-cpu
Probably because its a zillion TDP and it looks like your board supports 125W CPUs max.
MSI R9 290
CORSAIR VENGEANCE 8GB
CORSAIR H55
WD CAVIAR BLACK 1TB
5 CORSAIR FANS
I'm thinking of upgrading gpu to a PALIT GTX 970 JETSTREAM soon though.
Thanks
DJL99![]()
there as been testing done and if you Google there is lot of ppl running the two just fine was bios 19.9 or newer
PALIT or ASUS STRIX for GTX 970?
